V8 mid engine 4wd bay
Re: V8 mid engine 4wd bay
Postby BBWB » Sat Jul 01, 2017 8:25 am
^^^ $5.99 US per month with the lowest storage plan. Next step up is $9.99 US per month.
I did the free plan for years, just got tired of all the pop-up ads. ](*,) ](*,)
roverv8bay
Postby roverv8bay » Sat Jul 01, 2017 6:28 pm
roverv8bay
Postby roverv8bay » Fri Jul 07, 2017 9:08 pm
Gday all. this is the cross member for the front diff pretty simple set up. The chassis brackets are for setting up. better units will be made for the job
this is the location for the Mitsubishi bevel box. A very simple plate to mount it to chassis it uses 1 of the original kombi bolt holes
This is the plate needed to support the box to chassis
roverv8bay
Postby roverv8bay » Tue Jul 11, 2017 10:16 pm
next job building the rear diff centre mount. It will bolt onto the diff cover bolts & then to the original kombi upper gearbox mounting bracket.
This is the beginning of the front bumpstop rubber mounting to replace the original. Because of the relocation of the lower beam tube by 8 CM's there rubbers are to far apart.
step
1 Image
step2
step 3 slight tack weld to position it I have 4 new rubbers 2 65mm high 2 50mm high
roverv8bay
Postby roverv8bay » Thu Jul 13, 2017 1:00 am
rear diff mount finished 10mm plate cut with grinder & cut off drop saw.
This is the front crossmember to support the front of the rear diff
roverv8bay
Postby roverv8bay » Sat Jul 15, 2017 4:11 am
when I 1st installed the rear diff centre the left side gap for the axle shaft came up short. I figured I would have to use a beetle IRS axle but luck was on my side the Kombi unit fitted with enough plunge on the CV's
roverv8bay
Postby roverv8bay » Sun Jul 16, 2017 2:15 am
G'day all. I built the steering column support today. simple use of recycled Nissan part from behind the plastic bumper bar
Postby alykat » Sun Jul 16, 2017 6:37 am
Looks like it is coming along at a good pace.
Someone recently told me to "act my age" Screw them ! I'm having too much fun to act that old !
Postby Franz » Sun Jul 16, 2017 7:12 am
You're crazy. Getting it done though. =D>
Postby BBWB » Sun Jul 16, 2017 7:23 am
^^^ You said it Franz! This bus can never change hands again. It's going to require so much intimate knowledge if it ever needs a repair, a new owner would be pulling his hair out. Wink I really like it though, reminds me of my dad and some of his constructs. Smile
roverv8bay
Postby roverv8bay » Mon Jul 17, 2017 4:17 am
good evening all. Yes I have had a good run on the bus. I suffer from bursitis arthritis & torn rotator cuffs in both shoulders so the last couple of weeks I have had a bit of relief. I have a Facebook Page modified KOMBI & vw projects id anyone wants to check it out. I have alist of parts used so far on there
ernie
Postby john jones » Mon Jul 17, 2017 5:29 am
determined.. I wanna see a road trip in this rig.. Wink Wink Wink Wink
I feel like a campfire in the rain.. :-&
JWDII
Postby JWDII » Mon Jul 17, 2017 9:30 am
A+ for effort! this project is of a different breed! =D>
-- St. Francis Of Assisi.
