Author Message
<  Baywindow Central  ~  '71 Deluxe
Schmitty
PostPosted: Sat Apr 16, 2011 6:15 pm  Reply with quote
I'm hoping to get this thing running on its own power tonight. Gas tanks clean, I have a running engine, it's all wired up, new fuel line...
I'm just gonna jump the starter for now. Obviously, soon I'm gonna get the rest of the wiring figured out. But I don't have the key, so...
But everything's in place. I'll be ready to start playing with the starter as soon as I can get the hose clamp off the old fuel line that broke away at the tank.
Of course, video promised.
_________________
Jake
Back to top
View user's profile Send private message
Jobe
PostPosted: Sat Apr 16, 2011 11:18 pm  Reply with quote
what flip?
Hows it coming? Anxious
_________________
If you keep your mind closed, Keep your mouth shut too.
Back to top
View user's profile Send private message Yahoo Messenger
Schmitty
PostPosted: Sun Apr 17, 2011 2:44 pm  Reply with quote
Battery in... Wired up, ready to go... Clutch adjusted... New fuel line.... Gas...
And then the battery decided it wanted to be dead. Slight hold up, charging right now, should be ready here in a few minutes!
_________________
Jake
Back to top
Jobe
PostPosted: Sun Apr 17, 2011 4:07 pm  Reply with quote
what flip?
its been a few minutes.. :-)
_________________
Back to top
slammed and shiny
PostPosted: Sun Apr 17, 2011 7:34 pm  Reply with quote
driving? Dancing
_________________
Franz wrote:
.that late model shit is for late models.
Back to top
Schmitty
PostPosted: Sun Apr 17, 2011 7:47 pm  Reply with quote
Almost. I had it wired up right. It fires up, but runs horrible. To get it to stay running, you have to pump the gas really quickly. But that's with my brother's carb. My accelerator pump diaphragm is leaky, but it ran a lot better with my carb on there at Mike's house. I took it inside a while ago to verify that it was the diaphragm. But, it only leaks a little bit.
I'm gonna replace it very soon, I have to order it from the local auto parts store. But, in the meantime, it'll work to pull it back in the driveway!
_________________
Jake
Back to top
Schmitty
PostPosted: Tue Jun 07, 2011 1:15 pm  Reply with quote
Tomorrow is old Bruce's 40th birthday, and to celebrate, I'm finally getting a title and key! Finally came into some money, after months of not having ANY money, I suddenly got enough to get what I need. I'm sure nearly all of you can relate.
Not much progress lately, I've been busy with school and stuff, but now that school's out, I have nothing to do. Except work on my bus.
There's something up with the transaxle somewhere. I can feel it going into gear at the shifter, but when I put it into gear, it doesn't do anything or move anywhere. The brakes aren't locked up, it rolls just fine. Anyone have any clue what's up?
I'm gonna get this thing dropped soon, too. The nosebleed status is unmotivating.
_________________
Jake
Back to top
PostPosted: Tue Jun 07, 2011 7:52 pm  Reply with quote
Cool, so you're running and almost driving? Sound like maybe theres something wrong with the clutch....Or maybe the ring and pinion in the transaxle....does it make any grinding noises?
_________________
EverettB wrote:
Perfection breeds disappointment. Imperfection is happiness. Be happy with rust.
Back to top
View user's profile Send private message Send e-mail
Schmitty
PostPosted: Tue Jun 07, 2011 9:53 pm  Reply with quote
Its only made grinding noises very slightly once. And afterwards, I couldn't get it to grind again.
_________________
Jake
Back to top
Jobe
PostPosted: Tue Jun 07, 2011 10:36 pm  Reply with quote
what flip?
I have a nice recently resealed shortaxle type 1 with good brakes.
Its yours if you want. I'll even bring it to you soon,
the only catch is that you have to do the work yourself commit to getting right on it. you will need to buy a bus nose cone and shift fork. you should have everything else there for the conversion.
that would take care of your rear and give you the wide 5 like you want.
get a drum to drum linkpin beam, some adjusters, bushing, and 2" raise dual pattern sideplates, and ill help you build a beam and flipped spindles while im down.
_________________
Back to top
Jobe
PostPosted: Tue Jun 07, 2011 10:39 pm  Reply with quote
what flip?
And go over to my dads and get my squareback cleaned up/pictures taken so i can send you some more bus money bro. :-)
_________________
Back to top
PostPosted: Wed Jun 08, 2011 8:08 am  Reply with quote
Maybe you have a broken CV joint/axle?
_________________
Back to top
Schmitty
PostPosted: Wed Jun 08, 2011 10:16 am  Reply with quote
Yeah, maybe...
As soon as I can get a ride over there... It's been on my mind nonstop since we talked about it!
That sounds expensive :-) What's wrong with my nosecone?
_________________
Jake
Back to top
Schmitty
PostPosted: Sun Aug 07, 2011 9:25 pm  Reply with quote
http://www.youtube.com/watch?v=jnVnKZeKNAY
_________________
Jake
Back to top
Schmitty
PostPosted: Sun Aug 07, 2011 10:31 pm  Reply with quote
So... Who's going to BNNTA? :D
_________________
Jake
Back to top
Display posts from previous:
View next topic
View previous topic
Page 9 of 10
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Next
Kustom Coach Werks Forum Index  ~  Baywindow Central
Post new topic   Reply to topic
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Powered by phpBB and Ad Infinitum v1.06
