Author Message
<  Tech Articles  ~  How-to narrow a bay window bus beam.
PostPosted: Fri Jan 19, 2007 1:41 pm  Reply with quote
I HATE building these beams, they are very labor intensive. Here is a how-to, so that you can build your own...Because I'm done building these.
1)The first thing to do is scrape and remove as much dirt/greese as you can. Then carefully cut the welde so that you can remove the complete center pin carrier from the beam. On a bay window the beam tubes are flared/machined at the ends. Because of this you have to narrow the beam from the middle. I'm going to narrow this beam 4", so I'll have to remove exactly 4" from both tubes. Notice that I did not cut the 4" from the exact center. Instead I cut from the center block to 4" over. I did this so that when the beam is welded back together the welded area is not in the exact center of the beam where the adjuster will be.
2) Once the beam is cut in half its easy to remove the dust seal cups and bearings. I like to use a piece of pipe and a hammer. I remove the bearings to prevent damage to them when I'm welding on the new shock towers. Also notice that I left the inner bearings. They are located far enough in the tubes that they are not in danger of being damaged, plus they are easy to ruin when trying to remove them.
3) Remove the center block from the old tube sections. I like to carefully cut a slit in the tube and pry it apart so that the block will simply fall out. Next, make sure that the center block will easily slide into the regular beam tube, you may have to remove a little material from the O.D. with a belt sander. If the center block is tight in the beam tube, it will be hard to adjust later.
4) Be sure to slide the center block in BEFORE welding the beam back together. I like grind bevels on the ends of the tubes so that the weld will be very strong. Clamp the beam in a vice and use several C-clamps, then use a strait edge to make sure the beam tubes are strait. After the beam tubes are aligned corectly, start welding it back together. I'll weld as much as I can before removing any clamps, then I'll remove one clamp and welds as much as I can before removing another clamp.
5) Since the beam was narrowed from the middle, the mounting locations on the stock shock towers will be too narrow to fit the frame on the bus. To solve this problem I have custom 1/4" plate shock towers that mimic the shape of the orginal shock towers. You'll have to do some measuring and cut the shock towers out of 1/4" plate.
The first thing to do is weld some braces on both sides and ends of the beam tubes. These braces are temporary and will be removed once the shock towers are welded on. After the braces are in place, cut the shock towers off, I used a plasma torch...but you may have to get creative if you don't have access to one. Once the bulk of the shock towers are removed, clean the remaining weld/shock tower with a grinder.
6) I have a bus frame section that I use to build bus beams. I'm guessing that most of you won't. So, you'll have to do this step in the bus. Bolt your custom 1/4" plate towers to the bus and center your beam between them. Do as much welding as you can with it bolted in the bus to keep things from twisting/warping.
7) After the shock towers are welded on, remove it from the bus. Now you can cut the braces off. Re-weld your center pin carrier back on, postion it in the center of the lower tube. The center pin should be parallel to the beam tubes. Also notice that I welded a 2" x 1/4" gusset between the tubes on the back side of the shock towers for added strength.
8) Drill two 1/2" holes 1" apart in the center of the beam. Be careful on what angle you position them at, as it wil limit your adjustablilty. Then, cut between the two hole so that you have a slot for the adjuster bolt to move in. Finally weld the adjuster plate to the beam tube, take your time welding so that the beam tube does not warp.
9) Now that all of the cutting and welding has been done on the beam its time to re-install the bearing and dust seal cups. All thats left now is to narrow the tie rods and torsion springs the same amount as the beam.
Back to top
View user's profile Send private message Send e-mail
volkstypeone
PostPosted: Fri Jan 19, 2007 4:26 pm  Reply with quote
very well done. thanks franz. u the man
Note to anyone whos building a baybeam.
cut the upper bump stop befor pulling the trailings off.
argh. it will save u time
_________________
i am a volkswagen angel.
Back to top
volkstypeone
PostPosted: Mon Jan 29, 2007 12:24 pm  Reply with quote
if i set my adjusters at more of a "crazy angle"
will i run into the same problem bugs have when u do that.
that being that my front tires are goin to sit way Far foward having Major rubbing and turning issues with the fender?
_________________
Back to top
PostPosted: Mon Jan 29, 2007 2:14 pm  Reply with quote
Thats not really a problem on a bus. Yes the tire will rotate forward if you going to be low enough to have that much negitive arm angle. But at that point you're going to need tubs anyways...so you can make them big enough so that you're not going to have a turning problem.
Back to top
rustytortoise
PostPosted: Mon Jan 29, 2007 10:46 pm  Reply with quote
Alright, I'm glad you posted this. It's really going to help me with trying to do this. The only part I'm confused about is, when you but the center block back in the tubes, and weld the tubes back together, how do you located the center block to the center? It's probably simple and I'm just not thinking enough but if you could give me some guidance I'd appreciate it. Another question, where can I get these adjusters? Thank you for the how to.
Back to top
View user's profile Send private message Send e-mail AIM Address
Twiggy
PostPosted: Tue Jan 30, 2007 12:42 am  Reply with quote
that didn't seem that bad of a buildup, but then again the only thing I have narrowed is a B/J beam. Brick wall what a PITA.
Back to top
PostPosted: Tue Jan 30, 2007 9:48 am  Reply with quote
The adjuster block if free and allowed to slide around while its being built (just make sure its not resting in the area that your welding on Shame on you ) When the adjusters are installed, the 2 slots will locate the center block in the center of the beam with the adjuster screws.
Back to top
LOPHAT
PostPosted: Wed Jan 31, 2007 8:01 pm  Reply with quote
Nice one Franz!
_________________
Pants on the ground, pants on the ground...lookin like a FOOL with your pants on the ground. Hat turned sideways gold in your mouth...
Back to top
Kraftwerk
PostPosted: Fri Mar 02, 2007 2:31 pm  Reply with quote
Hey dude, i dont suppose you have a drawing or a few measurements for the end plates have you?? would just save me a little time so i can get my buddy to cut some out on his water jetcutter before i take the bus off the road!!
cheers
Lee
Back to top
PostPosted: Fri Mar 02, 2007 3:07 pm  Reply with quote
Sorry man, I custom made those. The best I can tell you is to set your beam on end and trace around your OG towers.
Back to top
stevep
PostPosted: Fri Mar 30, 2007 5:51 pm  Reply with quote
Is the flare machining at the end of the tube just a step for the gease seal holding do dah?
I'm wondering if it can be narrowed from the ends if one is prepared to sacrifice the grease seals.
Think
Back to top
volkstypeone
PostPosted: Wed May 02, 2007 3:38 pm  Reply with quote
http://www2.whidbey.net/ohmsmath/webwork/javascript/decin2fr.html
and
is ur best friend
_________________
Back to top
Nacho
PostPosted: Mon Aug 27, 2007 5:17 pm  Reply with quote
IS THIS THE SAME FOR A 72 BAY....?
_________________
http://beamscraps-vw.skynetblogs.be/
Back to top
View user's profile Send private message Send e-mail Visit poster's website
PostPosted: Mon Aug 27, 2007 5:42 pm  Reply with quote
yep
Back to top
dubdubz
PostPosted: Mon Nov 05, 2007 4:25 pm  Reply with quote
Franz - great writeup - I tried to narrow from the ends - now that was a pointless and hard task. I ended up spending several hours trawling through bearing books to get something that would fit after I cut the ends off!!
anyway back to my Q?
how did you know where to drill the holes for the centre slot? did you mark it before you cut?
Back to top
Display posts from previous:
View next topic
View previous topic
Page 1 of 4
Goto page 1, 2, 3, 4  Next
Kustom Coach Werks Forum Index  ~  Tech Articles
Post new topic   Reply to topic
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Powered by phpBB and Ad Infinitum v1.06
